[GRASS-user] r.terraflow usage (segfault)
Massimo Di Stefano massimodisasha at yahoo.it
Thu Nov 13 13:23:53 EST 2008
Hi
i'm tring to use "r.terraflow"
following the help page i see :
r.terraflow elev=spearfish filled=spearfish-filled \
     dir=spearfish-mfdir swatershed=spearfish-watershed \
     accumulation=spearfish-accu tci=spearfish-tci
but i can't find any "spearfish" elevation data in the spearfish dataset
so i used elevation.dem insted, but i've a segfault :-/
i tried with different locatiuon too, using:
as data input an elevetion model (230m resolution)
in a wgs84 UTM 33 N location
but i have segfault again....
mybe my knowledge of the r.terraflow application is not so good, and
i'm missing something to prepare the input data ?
i tried the same step having the same results
on a grass64 svn builded from source on different platforms
(ubuntu 8.04 32 bit , osx 10.5)
thanks for any help!
regards,
Massimo Di Stefano.
Chiacchiera con i tuoi amici in tempo reale!
 http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
