[GRASS-user] Import CH1903 Referenced Geodata
Helmut Kudrnovsky hellik at web.de
Thu Nov 13 16:36:11 EST 2008
Hi Adrian,
if you open a e00-file from the same web-site in an texteditor, you can find the following projection info:
  Projection        OBLIQUE
  Units             meters
 Spheroid          BESSEL
 Datum             user_defined 674. 14. 405.
 Parameters
 2                 /* Projection type < 1 | 2 >
 1                 /* Scale factor at the projection's center
 7 26 22.5         /* Longitude of the projection's center (DMS)
 46 57 08.66       /* Latitude  of the projection's center (DMS)
 90.000000         /* Azimuth at the projection's center
 -9419820.5907     /* False easting  (meters)
  200000.0000     /* False northing (meters)
Hope this helps to find and define the right projection to import the shapefile.
Best regards
helli
>Hello There,
>I'm trying to import the sample shapefile from
>http://www.swisstopo.admin.ch/internet/swisstopo/en/home/products/downloads/landscape/vector25.html
>(ArcView Shapefile) into GRASS 6.3.
>I guess the Coordinate Reference System for the data is CH1903+ /LV95,
>EPSG code 2056.
_________________________________________________________________________
Sensationsangebot nur bis 30.11: WEB.DE FreeDSL - Telefonanschluss + DSL
für nur 16,37 Euro/mtl.!* http://dsl.web.de/?ac=OM.AD.AD008K13805B7069a
