[GRASS-user] Returning to an old bug...
Richard Chirgwin rchirgwin at ozemail.com.au
Fri Nov 14 15:37:47 EST 2008
Glynn Clements wrote:
> Richard Chirgwin wrote:
>> A while back I noted that if patching very large numbers of files, GRASS
>> 6.3 generates frequent topo errors:
>> ERROR: BUG (Vect_build_sidx_from_topo): area does not exist
>> This can be reproduced in Spearfish:
>> 1) Create individual points
>> for i in `echo "select cat from bugsites" | db.select`; do
>> v.extract input=$i output="bugsites_""$i" where=cat=$i; done
>> 2) Buffer individual points
>> for i in `g.mlist vect pattern="bugsites_*"`; do
>> v.buffer input=$i output="buffer_""$i" buffer=500; done
>> 3) Add tables to buffers
>> for i in `g.mlist vect pattern="buffer_*"`; do
>> v.db.addtable map=$i; done
>> 4) Overlay buffers with areas
>> for i in `g.mlist vect pattern="buffer_*"; do
>> v.overlay ainput=$i binput=trn_sites output="overlay_""$i" operator=and;
>> done
>> 5) Create target patch map
>> for i in `g.mlist vect pattern="overlay_*"`; do
>> v.patch -a -e input=$i output=patch --overwrite; done
>> Can anyone suggest solutions? It would be nice to avoid having to patch
>> a bunch of maps by hand to avoid the error!
> Run v.build after each v.patch:
> 		v.build patch
> 	done
Ok, that does the trick; thank you Glynn, also Markus (and my apologies
for my typos in the e-mail!).
I had assumed that the topology build within the patch process should work!
Cheers,
Richard
