[GRASS-user] Returning to an old bug...
Fri Nov 14 18:37:16 EST 2008
Markus Neteler wrote:
> > I had assumed that the topology build within the patch process should work!
> Me, too. I see that
> Vect_build(&OutMap);
> isnt't there in the
>         if (append->answer) {
> part. May that be the problem?
Maybe the idea is that you might want to perform multiple appends
(ignoring the warnings) then just rebuild the topology once at the
end?
It might be worth checking whether this still produces the correct
result. If it does, it will be quicker than rebuilding the topology at
each step.
