[GRASS-user] Rename multiple sqlite columns at once
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Tue Nov 18 20:41:27 EST 2008
On Tue, 2008-11-18 at 17:07 -0800, Dylan Beaudette wrote:
> On Tuesday 18 November 2008, Nikos Alexandris wrote:
> > On Tue, 2008-11-18 at 15:12 +0100, Nikos Alexandris wrote:
> > > On Sat, 2008-11-15 at 23:53 -0800, Hamish wrote:
> > > Hamish,
> > > sorry for not following up. I've tried your suggestion and there was
> > > some error. I can't provide details now (working in another machine).
> > > I'll do so later... :-)
> > # trying with a grass-vector
> > ##(following the example & terminology used in the page "drv_gpx.html")
> > ogr2ogr -f "ESRI Shapefile"
> > befliegung_test.shp
> > /geo/grassdb/rlp_fgaps/gk2_opt6_test/PERMANENT/vector/befliegung/head -sql
> > "select AREA AS area, PERIMETER AS perimeter from
> > /geo/grassdb/rlp_fgaps/gk2_opt6_test/PERMANENT/vector/befliegung/head"
> > ERROR 1: SQL: Missing comma after column AREA in SELECT statement. ## I
> > don't think that a comma is required after the "field" name
> > I get the same ERROR when trying on a shapefile.
> > Nikos
> Yeah... I have had the error before as well. Was using GDAL-trunk.
> Cheers,
> Dylan
Using gdal stable here!
Nikos
