[GRASS-user] GRASS tools for palsar/radar images
Maning Sambale
emmanuel.sambale at gmail.com
Fri Nov 21 08:31:46 EST 2008
Daniel,
Thank you for the links.
cheers
maning
On Fri, 2008-11-21 at 11:34 +0000, Daniel McInerney wrote:
> Hi Maning,
> I'm not aware of any GRASS tools to process radar
> data, but you could have a look at Polsarpro [1],
> which handles ALOS Palsar data and is available for
> various operating systems. Best [2] might also be of
> use if you're using ASAR data.
> [3] is referenced in Markus and Helena's book and
> you may find some useful tools there.
> Regards,
> Daniel.
> [1] http://earth.esa.int/polsarpro/
> [2] http://earth.esa.int/services/best/
> [3] http://www.asf.alaska.edu/sardatacenter/?q=softwaretools
> maning sambale wrote:
> > Hi,
> > I'm looking for some tools in processing radar/palsar data.
> > pre-processing, image classification, etc.
> > So far, I found RAT radartools http://srv-43-200.bv.tu-berlin.de/rat/index.php
> > Any GRASS user doing radar processing?
> > cheers,
> > maning
