[GRASS-user] G_malloc: out of memory
Kurt Springs ferret_bard at mac.com
Sun Nov 23 17:17:09 EST 2008
Well, it is installed, but it is still not snapping the nodes.  (BTW I
like the way it works otherwise).  One thing, how do I set the
keyboard keys command, option/alt, and control to work with the mouse
click for middle and right mouse button.  Things did not perform as
expected when I tried middle or right mouse keystrokes when I tried to
connect a box around the coastline.
On Nov 23, 2008, at 3:42 PM, William Kyngesburye wrote:
> On Nov 22, 2008, at 7:42 PM, Kurt Springs wrote:
>> Okay, I'm willing to try.  I hope 6.4 will help in getting nodes to
>> snap.
>> Kurt
>> On Nov 22, 2008, at 11:22 AM, William Kyngesburye wrote:
>>> I'm somewhat caught up on other distractions and can focus more on
>>> GRASS again.  I can package up a 6.4svn.
>>> If your up to it, there are detailed OSX compile instructions in
>>> the source, though I should look them over for any changes needed.
> I have 6.4 SVN binaries online now.  Tested on Leopard so far.  I
> also updated the build instructions in the source.
> A couple important changes from my previous binaries (the build
> instructions also reflect these changes):
> - It uses ActiveTcl 8.5 now for the TclTk GUI and NVIZ.  This "aqua-
> fies" the TclTk GUI.  The X11 TclTk is not bundled now and not needed.
> - It uses up-to-date wxPython binaries, even on Leopard.  Starting
> with wxPython 2.8.8, it can install to be used with the Leopard
> system Python 2.5 as well as the python.org Python.  This may
> interfere with the wx gui in GRASS 6.3, but it's not as well
> developed anyways.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> [Trillian]  What are you supposed to do WITH a maniacally depressed
> robot?
> [Marvin]  You think you have problems?  What are you supposed to do
> if you ARE a maniacally depressed robot?  No, don't try and answer,
> I'm 50,000 times more intelligent than you and even I don't know the
> answer...
> - HitchHiker's Guide to the Galaxy
