[GRASS-user] Compile grass6_devel with ffmpeg support?
Sun Nov 23 20:57:42 EST 2008
Nikos Alexandris wrote:
> thanks for the support. I can't *locate* the avformat.h file under my
> system. I can't find any ffmpeg-dev package in the ubuntu repositories.
> I even did try to compile grass after compiling ffmpeg latest source
> code [1]. No luck.
> There was no issue in Ubuntu 7.10 64-bit. With Ubuntu HH and now II
> there always was a problem but I never had a closer look. Broken ubuntu
> package or broken ffmpeg source code?
The files are still there in the latest source code:
	http://svn.ffmpeg.org/ffmpeg/trunk/
I don't know whether they still get installed, or where.
