[GRASS-user] [Fwd: grass-related failure when building qgis_0_11]
Markus Neteler neteler at osgeo.org
Mon Nov 24 12:45:29 EST 2008
Nikos,
this has been fixed recently in QGIS trunk.
Markus
On Mon, Nov 24, 2008 at 6:24 PM, Nikos Alexandris
<nikos.alexandris at felis.uni-freiburg.de> wrote:
> Sorry for forwarding this in the grass-user list. I must have
> messed up somehow my grass-dev account or I don't know what... I can't
> send anything to grass-dev(?).
> Regards, Nikos
> ---------- Forwarded message ----------
> From: Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>
> To: grass-dev at lists.osgeo.org
> Date: Mon, 24 Nov 2008 07:49:10 +0100
> Subject: grass-related failure when building qgis_0_11
> Hi all! I get this error when building qgis 0.11 from source. I've read
> the http://trac.osgeo.org/grass/ticket/364 ticket. Is it really fixed?
> This problem does not occur when building qgis preview version.
> [ 71%] Building CXX object
> src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrassprovider.o
> /usr/local/grass-6.4.svn/include/grass/Vect.h: In static member function
> 'static int QgsGrassProvider::openMap(QString, QString, QString,
> QString)':
> /usr/local/grass-6.4.svn/include/grass/Vect.h:197: error: too many
> arguments to function 'int Vect_build(Map_info*)'
> /usr/local/src/qgis_0_11_0/src/providers/grass/qgsgrassprovider.cpp:1040: error: at this point in file
> /usr/local/grass-6.4.svn/include/grass/Vect.h: In member function 'bool
> QgsGrassProvider::closeEdit(bool)':
> /usr/local/grass-6.4.svn/include/grass/Vect.h:199: error: too many
> arguments to function 'int Vect_build_partial(Map_info*, int)'
> /usr/local/src/qgis_0_11_0/src/providers/grass/qgsgrassprovider.cpp:1495: error: at this point in file
> /usr/local/src/qgis_0_11_0/src/providers/grass/qgsgrassprovider.cpp:1496: error: at this point in file
> make[2]: ***
> [src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrassprovider.o] Error
> 1
> make[1]: *** [src/providers/grass/CMakeFiles/qgisgrass.dir/all] Error 2
> make: *** [all] Error 2
> Nikos
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
