[GRASS-user] Grass-GIS 6.4 on OSX
William Kyngesburye woklist at kyngchaos.com
Wed Nov 26 00:55:13 EST 2008
On Nov 25, 2008, at 11:22 PM, Glynn Clements wrote:
> First, note that the Xerces check in the v.in.wfs script is broken; it
> uses "ldd", which (AFAIK) is specifc to Linux. You might want to try
> removing the lines:
> 	if [ -z "`ldd $OGRINFO | grep xerces`" ] ; then
> 	  g.message -e "OGR needs to be compiled with xerces-c support"
> 	  exit 1
> 	fi
> from the $GISBASE/scripts/v.in.wfs file.
Even if there is a similar tool on OSX (otool provides that info),
this will only work if Xerces is linked as a shared library.  I build
my GDAL framework with a static Xerces since GDAL is the only thing
I've encountered so far that uses it.
I see another problem - OSX does not have lynx.  Wouldn't curl or wget
work for this, and be more universally available? (curl for OSX)
> Other than that, I don't know whether William's GDAL framework
> includes Xerces. If it doesn't, you'll probably need to build GDAL
> (and possibly Xerces itself) from source.
It does.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
