[GRASS-user] Re: combining and evaluating vector dbf values
Markus Neteler neteler at osgeo.org
Wed Nov 26 04:36:41 EST 2008
On Tue, Nov 25, 2008 at 9:07 AM, maning sambale
<emmanuel.sambale at gmail.com> wrote:
> Nearly there but not quite:
> The final column should combine the values from the 2 columns, am I
> right that concat doesn't work with dbf?
> So this doesn't work
> echo "UPDATE vectormap SET c_COVER = a_COVER || a_value" | db.execute
Did you try the SQLite driver?
Just create a new mapset, define the connection with "db.connect" (see manual
for copy-paste command) and "g.copy" the map from the DBF mapset
into the sqlite mapset.
Then the joys of SQL are available.
Markus
