[GRASS-user] Going back to 6.3
Kurt Springs ferret_bard at mac.com
Wed Nov 26 10:16:39 EST 2008
It was a s a surface raster map generated from an ascii file.  It just
seems that when v.digit crashes, regardless of the version, I am in
for trouble.
Kurt
On Nov 25, 2008, at 11:51 PM, William Kyngesburye wrote:
> On Nov 25, 2008, at 10:33 PM, Kurt Springs wrote:
>>> If you are using my GRASS 6.3, there is no need to delete
>>> ActiveTcl.  It has its own internal TclTk X11 binaries that it
>>> explicitly uses.  In fact, no need to delete 6.3 before installing
>>> 6.4.
>> 6.4 actually overwrote 6.3.  I'd assumed the reverse would be true.
> Odd, GRASS 6.3 and 6.4 have different names:
> GRASS-6.3.app
> GRASS-6.4.app
>>>> Also, the surface raster I generated from the ASCII files only
>>>> displays white now.  Is there anyway to recover that once I go
>>>> back to 6.3?
>>> Rasters should be compatible between 6.4 and 6.3.
>> Something when v.digit crashed actually made it unreadable.
> Also odd - why a vector would affect a raster.  Or did you mean
> surface _vector_?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that
> the past isn't a fiction designed to account for the discrepancy
> between my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
