[GRASS-user] Grass-GIS 6.4 on OSX
Wed Nov 26 12:47:35 EST 2008
Richard Chirgwin wrote:
> So which would be safer, to remove the check from v.in.wfs, or try some
> other workaround?
Remove the check.
> By the way, the error from v.in.wfs is "OGR needs to be compiled with
> xerces-c support".
Right. This is printed by the script when it fails to detect Xerces
support (in this case, because the check is broken).
