[GRASS-user] v.in.dxf crashes
Michael Barton
michael.barton at asu.edu
Wed Nov 26 12:42:56 EST 2008
On Nov 26, 2008, at 10:00 AM, <grass-user-request at lists.osgeo.org>
wrote:
> Message: 5
> Date: Wed, 26 Nov 2008 10:56:30 -0600
> From: William Kyngesburye <woklist at kyngchaos.com>
> Subject:
> To: Kurt Springs <ferret_bard at mac.com>
> Cc: GRASS user list <grassuser at grass.itc.it>
> Message-ID: <0382A5B6-C4D1-462E-A32E-EC51A09F00DF at kyngchaos.com>
> Content-Type: text/plain; charset=US-ASCII; format=flowed; delsp=yes
> On Nov 26, 2008, at 9:14 AM, Kurt Springs wrote:
>> On GRASS 6.3 I use X11 on Mac OS X 10.5.5 (aka Leopard). I agree
>> that the problem is with Active tcl 8.5. Having used the two, I
>> have found X11 to be much more stable. How easy would it be to
>> compile a 6.4 to use X11?
> Not hard at all...
Actually, except for NVIZ, you don't even have to compile anything. If
you have TclTk for x11, you can just set GRASS_WISH to the wish file
for that version of TclTk. You need to do this in your bash .profile
file and not in the .grassrc6 file. Then all of GRASS will be in the
x11 version except for NVIZ.
Michael
> Note that not only is the type of TclTk different - Aqua vs X11, but
> the version as well: 8.4 X11 for GRASS 6.3, 8.5 Aqua for GRASS 6.4.
> Maybe there is an issue with TclTk 8.5?
> It's not possible to build a working (for GRASS) TclTk 8.4 Aqua - some
> Aqua issues were fixed in 8.5.
> I guess the thing to try is TclTk 8.5 X11, to test if it's a version
> problem.
> Do you have a small DXF that crashes for you that I could test with?
>>>>>> I tried a simple layer and it still crashed. I got the message
>>>>>> "The application Wish quit unexpectedly."
>>>>>> I didn't have this problem with 6.3.
> Check for a crashlog in Console.app. This could help. Especially
> since it would have some paths to verify which wish is running.
>>> I don't think that the wish related part in GRASS 6.3 was different.
>>> More likely, did you use a different Tcl version?
>>>>>> In Console Messages I get:
>>>>>> 11/25/08 1:10:45 PM Terminal[8482] .sdef error: Operation
>>>>>> could not be completed. (NSXMLParserErrorDomain error 1549.)
>>>>>> 11/25/08 1:10:45 PM Terminal[8482] line number: 2
>>>>>> Hope this means something to someone.
>>> Searching in the net shows a couple of similar messages, apparently
>>> related to Active tcl 8.5 (and not GRASS).
>>> Markus
> ActiveTcl or Aqua TclTk? (google didn't turn up anything for me)
> sdef... that's scripting (Applescript) definitions for OSX (Wish.app
> is scriptable, to run a Tcl script). ... the AS dictionary for
> wish.app opens in Script Editor... Wish.app runs fine alone...
> hopefully a crashlog will help...
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> End of grass-user Digest, Vol 31, Issue 59
