[GRASS-user] Varying results - v.select,v.distance,v.what
Markus Neteler
neteler at osgeo.org
Wed Nov 26 15:56:01 EST 2008
On Thu, Nov 20, 2008 at 9:03 PM, Kevin Webb <kfw4 at cornell.edu> wrote:
> v.db.connect -p indicates layer#2 is keyed by the <cat> field yet I don't
> see a 'cat' field in the v.info output,
> shouldn't there be a 'cat' column in layer#2 or am I misinterpreting how
> multiple layers are properly added to a vector?
Yes, a cat column should always be there AFAIK.
Can you put the packages location somewhere with copy.paste commands
to try? Offlist, if needed for privacy.
Markus
