[GRASS-user] Best way to reconnect tables in grass' databse
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Thu Nov 27 18:43:41 EST 2008
On Fri, 2008-11-28 at 00:18 +0100, Markus Neteler wrote:
> On Fri, Nov 28, 2008 at 12:16 AM, Nikos Alexandris
> <nikos.alexandris at felis.uni-freiburg.de> wrote:
> > This seem to require another treatment... ?
> > # editing the file and saving changes
> > nik at vertical:/usr/local/src/grass6_devel$ nano
> > scripts/v.db.reconnect.all/v.db.reconnect.all.tmp.html
> This is the temporary file, not the file in SVN (which
> is description.html in 6.x and modulename.html in 7).
> Just copy over your changes into the right html file and
> svn diff will work.
> Markus
Well, I thought so (that description is the file to be edited) but it
(=description.html) has only one sentence in it:
cat /usr/local/src/grass6_devel/scripts/v.db.reconnect.all/description.html
<H2>DESCRIPTION</H2>
<EM>v.db.reconnect.all</EM> changes database connection of all layers of
all vectors in the current mapset from old_database to database. If a
link
does not match the old_database it is left untouched.
<H2>AUTHOR</H2>
Radim Blazek
<p>
<i>Last changed: $Date: 2007-04-17 01:41:41 +0200 (Tue, 17 Apr 2007)
$</i>
Anyhow, I'll copy the whole file (I think it's not wrong -- or is it?)
Cheers, Nikos
