[GRASS-user] gdal, v.in.ogr, Ubuntu intrepid
Paolo Craveri pcraveri at gmail.com
Sat Nov 29 03:18:26 EST 2008
Hi all,
troubles remain...
I removed  gdal library by synaptic and then I compiled gdal and
grass6.4 svn, but the error remains.
I've also tried to remove and  install everything from synaptic
(grass6.3), without improvement.
I only  have one version of gdal installed.
Does someone use gdal 1.5.2 /1.5.3 and GRASS 6.4 svn (or GRASS6.3) in
Ubuntu Intrepid without errors when working with v.in.ogr/v.in.gdal
etc. ?  It would be great if you tell me how can I get my system
working.
Many thanks in advance. ciao to all.
Paolo C.
Lat. 44° 39' 11.08'' N  Long. 7° 23' 25.26'' E
2008/11/25 Jasiewicz Jarosław <jarekj at amu.edu.pl>:
> There is a problem with gdal_translate in that package. Download and compile
> gdal 1.5.3 and compile grass again. It should help.
> Jarek
> Paolo Craveri pisze:
>> Dear grass users
>> I have just read this thread
>> http://www.nabble.com/GRASS-6.4-and-Ubuntu-Intrepid-td20222308.htm
>> but I cannot understand clearly what can I have to do to avoid this:
>> GRASS 6.4.svn (piemwgs84_prova):~/script_grass > v.in.ogr -o
>> dsn=/media/disk/gis/shapefiles/  layer=polyRiserve output=riserve
>> type=point,line,boundary,centroid snap=1 –o
>> *** buffer overflow detected ***: v.in.ogr terminated
>> ======= Backtrace: =========
>> I get the same output as reported in the thread above.
>> I have two GRASSS installed (6.3 from les-ejk.cz ubuntu 8.10
>> repository and 6.4svn compiled) ;  libgdal1-1.5.0,
>> libgdal1-1.5.0-grass, libgdal1-dev have been installed by Synaptic.
>> I've already removed libgdal1-1.4 but the problem still remains.
>> I'm working in Ubuntu Intrepid (8.10) of course.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Paolo C.
