[GRASS-user] Re: Gui error behind splash screen
Maris Nartiss maris.gis at gmail.com
Sat Nov 29 09:25:06 EST 2008
Another GRASS+Ubuntu segfault. Use search to get more info. In short:
remove GRASS and all of it's dependencies and complie new ones FROM
SOURCE! (or choose some better user-friendly distribution like Gentoo)
Maris.
2008/11/29, Daniel Victoria <daniel.victoria at gmail.com>:
> another update. I can get into a lat lon location in the grass
> terminal but g.region -p gives me a segmentation fault
> On Sat, Nov 29, 2008 at 11:26 AM, Daniel Victoria
> <daniel.victoria at gmail.com> wrote:
>> An update. Just found out that everything works fine with an UTM
>> location but, the failure happens when I try a lat-lon location.
>> Here is my wind file:
>> proj:       3
>> zone:       0
>> north:      7S
>> south:      15S
>> east:       57W
>> west:       67W
>> cols:       3704
>> rows:       2963
>> e-w resol:  0:00:09.719222
>> n-s resol:  0:00:09.719879
>> top:        1
>> bottom:     0
>> cols3:      1
>> rows3:      1
>> depths:     1
>> e-w resol3: 1
>> n-s resol3: 1
>> t-b resol:  1
>> Don't see anything wrong...
>> Daniel
>> On Fri, Nov 28, 2008 at 4:45 PM, Daniel Victoria
>>> Hi all,
>>> I just installed grass6.3 from les-ejk repository on a very striped
>>> down ubuntu machine and I can create the location and mapset with no
>>> problem in the GUI. The problem is that, after I create the mapset and
>>> grass tries to load the gis.m it gives me an error message which I can
>>> not see because it's behind the splash screen.
>>> Could it be a tcl/tk version problem? I believe I have both 8.4 and
>>> 8.5. On the other hand, the location chooser gui works fine...
>>> Thanks
>>> Daniel
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
