[GRASS-user] maximum zoom-in reached
H.S.Rai hardeep.rai at gmail.com
Sat Nov 29 21:32:14 EST 2008
On Sat, Nov 29, 2008 at 8:34 PM, Maris Nartiss <maris.gis at gmail.com> wrote:
> gis.m gives "Maximum zoom-in reached" error when display width/height
> is smaller than one column/row. If You have data with higher
> resolution, You have to adjust Your region settings (increase
> resolution). See g.region how to set resolution.
Thanks to all for prompt and appropriate responses. Default region was
with resolution 1. I anticipated this and changed to .0001, but may be
I was not able to do it properly, and was not able to get zoom in.
Then I existing GRASS, restarted, and it worked fine.
$ g.region -p
projection: 1 (UTM)
zone:       0
datum:      wgs84
ellipsoid:  wgs84
north:      36.56820636
south:      6.09470106
west:       66.77269446
east:       98.66413062
nsres:      0.0001
ewres:      0.0001
rows:       304735
cols:       318914
cells:      97184257790
H.S.Rai
