[Qgis-user] Re: [GRASS-user] Problem importing/viewing a ~160MB shapefile
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Sun Nov 30 07:42:45 EST 2008
On Sat, 2008-11-29 at 19:01 -0800, Hamish wrote:
> Nikos wrote:
> > While QGIS (unstable, revision 9711) can open and report GRASS' region
> > setting for a lat-long location and load/view the above mentioned
> > "coastline" dataset (both the shapefile and the GRASS vector, the one
> > after v.in.ogr -c and NOT after v.clean!!), GRASS reports the error:
> > g.region -p
> > ERROR: default region is invalid
> >        line 4: <south: 90:22:00.17015S>
> latitude > 90deg can not exist.
What might be the reason creating this "illegal" latitude value?
# the shapfile seems to be "legal"
# ogrinfo coastlines.shp -al -so
INFO: Open of
`/geo/geodata/world/coastlines/coastlines_HR/coastlines.shp'
      using driver `ESRI Shapefile' successful.
Layer name: coastlines
Geometry: Polygon
Feature Count: 181148
Extent: (-180.000000, -90.000000) - (180.000000, 83.633286)
Layer SRS WKT:
GEOGCS["GCS_WGS_1984",
    DATUM["WGS_1984",
        SPHEROID["WGS_1984",6378137.0,298.257223563]],
    PRIMEM["Greenwich",0.0],
    UNIT["Degree",0.0174532925199433]]
> fix it in line 4 of $LOCATION/PERMANENT/DEFAULT_WIND or from within the
> PERMANENT mapset run "g.region -s" to set the current (valid) region
> to be the default one.
Instead I created a new location (g.proj -c georef=TheShapefile
location=...) and it works.
# region report
# no rasters present, so no interest for resolution(right?)
g.region -p
projection: 3 (Latitude-Longitude)
zone:       0
datum:      wgs84
ellipsoid:  wgs84
north:      83:37:59.82985N
south:      90S
west:       180W
east:       180E
nsres:      8:40:53.991492
ewres:      18
rows:       20
cols:       20
cells:      400
> WRT large shapefiles: your buffer overflow/segfault probably has little
> to do with the size of the file. Others regularly load much bigger
> shapefiles into/out of grass. Large file errors typically start to show
> themselves around the 2GB mark. You need to run a GDB backtrack to see
> the cause.
I want to believe that segfaults were related with Ubuntu 8.10 + gdal
1.5.3. I think I have found another, recent, reference about this in the
archive.
> the "florida coastline" problem (processing huge single polyline
> boundaries) does not result in the program breaking. it is just an
> inefficient method which takes a very very long time. It will not result
> in a buffer overflow or a segfault. That is something different.
* The shapefile I am trying to "work-out" is a coastline dataset as
well. But it never really goes through the v.in.ogr process or the
"v.in.ogr -c" + "v.split" + "v.clean tool=break" (see previous posts on
this thread of course). It always "hangs" at the "breaking boundaries"
step.
* Question: What's the difference between of "polygon" and "boundary"?
* Why the "break polygons" step during "building" process? I thought
that there are *only* -nodes & primitives- points, centroids, lines,
boundaries, areas, isles
* After stopping the process "Ctrl+C" v.info complains (naturally I
guess) about:
ERROR: Unable to open vector map <cstlns_global at PERMANENT> on level 2.
Try
       to rebuild vector topology by v.build.
* Then, v.build warns:
WARNING: Coor files of vector map <cstlns_global at PERMANENT> is larger
than
         it should be (29979221 bytes excess)
and starts working.
* Question: How long should I leave the system working? As long as it
takes? My last attempt was >30 hours.
> How about "v.in.ogr spatial=" ?
> Hamish
It works, at least over Greece :-). But this does not resolve the
"problem", does it? In case one needs the whole vector map (in my case a
global dataset) it shouldn't be necessary to import it step-wise.
Regards, Nikos
