[GRASS-user] flip raster
José María Michia jose.maria.michia at gmail.com
Wed Oct 8 22:48:07 EDT 2008
2008/10/8 Nikos Alexandris <nikos.alexandris en felis.uni-freiburg.de>:
> On Tue, 2008-10-07 at 01:37 +0100, Glynn Clements wrote:
>> José María Michia wrote:
>> > I've imported a NetCDF file (ETOPO1 model). The resulted raster appears
>> > flipped vertically. How can I fix this? I try with mapcalc, without success:
>> > - neighborhood modifier: not accept computations in offset parameter, like
>> > map[0,total_rows-row()]
>> > - I dont know how to query map in arbitrary coordinates, like
>> > map(x(),-1*y())
>> There isn't any mechanism in r.mapcalc to achieve this. I'm not sure
>> that it's possible to do it entirely within GRASS. Flipping
>> geo-referenced data doesn't really make much sense.
>> Either figure out how to import it with the correct orientation, or
>> export it, flip the exported data, then re-import.
> Glynn and All,
> excuse me for hijacking the post. I am looking for a way (just for the
> fun of the game or for philosophical re-search) to rotate geotiffs at
> 180 degrees (i.e. flip vertically and horizontally). I've posted about
> this in the gdal-dev list [1].
> Is there a way to accomplish a 180 deg. rotation using the
> listgeo/geotifcp command line tools?
I'm not sure, but maybe this can be useful:
Alexander Schulze suggested me that I use the library to invest CDO latitudes:
Something like:
cdo invertlat filein fileout1
cdo invertlon fileout1 fileout2
If you can use netCDF format, look at this:
http://nco.wiki.sourceforge.net/reverse a dimension
José María
> Thank you, Nikos
> [1] http://lists.osgeo.org/pipermail/gdal-dev/2008-October/018548.html
