[GRASS-user] Problem with the signatures from i.class
Daniel Victoria daniel.victoria at gmail.com
Thu Oct 9 07:49:48 EDT 2008
Are you sure your signature file is OK? Could you post the signature
file? It's located in
<location>/<mapset>/group/<group_name>/subgroup/<sub_group name>/sig/
-- Now in Portuguese --
Vc checou o seu arquivo de assinatura? Ele pode ter sido gerado com
algum problema. O arquivo de assinatura se encontra no diretório
E seu inglês esta muito bom
On Wed, Oct 8, 2008 at 10:41 PM, Thybério Luna Freire
<thyberio at gmail.com> wrote:
> Hi,
> i'm using i.class to generate a signature to run on i.maxlik. The module
> read the signature with no problem, but, the class map result shows only one
> class and the area that its cover is bigger than the region that i've set in
> i.class. Thats a large red rectangle. I tried various standard deviations
> but the result is always the same.
> what can be happening?
> Sorry, i'm brazilian and my english is not very good!
> thanks
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
