[GRASS-user] re: streams under r.watershed
Kurt Springs ferret_bard at mac.com
Tue Oct 14 22:48:26 EDT 2008
Thanks Annalisa,
That does help immensely.  Hopefully, it will tell me something useful
about how the location for these monuments was constructed.
Kurt
On Oct 14, 2008, at 4:25 AM, Annalisa Minelli wrote:
> Hi Kurt!
> I work/study Hydrology and I use GRASS in my work... so, for my
> short experinece, I can tell you:
> the "stream map", generated by r.watershed (or r.watershed.fast) is
> the map of the reaches, so the colors you can see and the numbers
> (categories) associated with each reach (you can see it if you query
> the map) is simply an "id" of the reach (it is useful to distinguish
> the reaches...).
> r.watershed extracts these stream segments from the DEM basing his
> analysis on the elevation data... so, depending on the "threshold"
> value you give him in input, the module will return a different
> result (so it happens that if you give a threshold value greater you
> will see in your map only principal reaches, or if you give a lesser
> threshold value you will obtain more and more reaches - more dense
> network -).
> A way to isolate some reaches -remainig in raster format- could be
> using r.reclass:
> type "r.reclass" in the shell: it requires you the name of the map
> to reclassify, the name of a new map (reclassified) and the values
> of the categories to change (e.g. I want category 30 to become
> category 1... so I type: 30 = 1).
> To do this you can query the map for the reaches you interest and
> read the actual category (e.g. 30,32,34) then type:
> > r.reclass
> name of the new map: OPTION:   Raster map to be reclassified
>      key: input
>   format: name
> required: YES
> Enter the name of an existing raster file
> Enter 'list' for a list of existing raster files
> Hit RETURN to cancel request
> > streams    #from r.watershed
> <streams>
> OPTION:   Name for output raster map
>      key: output
>   format: name
> required: YES
> Enter a new raster file name
> > WhatYouWant   #the name of the new map I'm going to create
> <WhatYouWant>
> OPTION:   File containing reclass rules
>      key: rules
>   format: name
> required: NO
> Enter the name of an existing input file
> >                        #I have not a file containig the rules...
> OPTION:   Title for the resulting raster map
>      key: title
> required: NO
> enter option >  #I choose not to give a title to the map I'm going
> to create
> Enter rule(s), "end" when done, "help" if you need it
> Data range is 2 to 66
> > 30 = 1           #...I prefer entering the rules by myself
> > 32 = 2
> > 34 = 3
> > end
> so you can open your "WhatYouWant" raster map where you will see
> only the reaches you selected by category.
> Hoping I've been helpful...
> Annalisa
> 2008/10/14 Kurt Springs <ferret_bard at mac.com>
> Thanks to Hamish and Markus Metz,
> What I am doing is comparing two or three (possibly four) types of
> megaliths in my study area and trying to understand the relation
> ship between both contemporary monuments and later monuments.  While
> I was looking at old GIS maps, I was looking at the stream and basin
> maps and had overlaid the monuments on these maps.
> First off, the vector river and stream maps, representing the
> current water ways are a bit different then the stream map.  The
> physical streams do seem to follow the stream maps, but there are
> many more branches on the stream map than there are actual streams.
> Some of the megalithic tombs types seem to fall into the web of the
> streams, while others don't.  I think this is important.  I am,
> unfortunately, an archaeologist, not a hydrologist, so I am not up
> on watershed lingo.
> What I need to know is what information on these maps may tell me
> something important.  For example, are the stream systems shown on
> the watershed stream maps just important of them selves, or might
> the values the colors represent tell me something?  Is there a way
> to isolate them?
> I guess what I am hoping for is a hydrologist who uses grass and can
> explain what I am looking at in the real world.
> Kurt Springs_______________________________________________
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081014/b6493f6e/attachment-0001.html
