[GRASS-user] How to install Grass into Ubuntu
G. Allegri giohappy at gmail.com
Mon Oct 20 05:41:33 EDT 2008
Hi Matt,
it depeds who are these "users". If you run grass as "you", you can
manage mapsets in your home folders without having to run it with
sudo... If you want to work on others' homes you need the sudo
permissions, as any other operation.
2008/10/20 Matt B <mattslists at gmail.com>:
> Hello list,
> I'm using Grass on ubuntu 8.04. Weird thing is that unless I run it "sudo
> grass" I get a bunch of errors (and it's unusable) related to grass not
> having the correct permissions to write to where I keep the data (ie the
> users home directory). It's not a show stoppper at the moment and only
> slightly annoying. I'm not sure why this is but I have some ideas to hunt
> down when I get time. I used the standard ubuntu install and assume its
> something to do with the ubuntu setup script.
> Matt
> On Mon, Oct 20, 2008 at 7:10 PM, Jhon Ortiz <eljhonjhon at hotmail.com> wrote:
>>   RE: [GRASS-user] How to install Grass into Ubuntu
>> > > sudo apt-get install grass
>> > The offical Ubuntu repositories are a bit outdated. A more updated
>> > repo is the one from Jachym: http://www.les-ejk.cz/ubuntu/
>> > The Gutsy one has Grass 6.3.0, updated to May 2008.
>> Im working with Ubuntu 7.10 Gutsy and in this repositories
>> not is available the version 6.3.0, the laster version in this
>> repositories is 6.2.2 (http://www.les-ejk.cz/ubuntu/).
>> The people who working in Ubuntu and want to work with
>> other version have to compile it. It's not a so hard task.
>> http://grass.osgeo.org/wiki/Compile_and_Install
>> > If you want newer versions... you need to compile it. It's not a so
>> > hard task, and we can give advices.
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
>> Ahora llévate lo mejor de MSN y Windows Live, en tu móvil
