[GRASS-user] configure: error: *** Could not determine External PROJ.4 version."
Tue Sep 9 19:45:08 EDT 2008
Laura Toma wrote:
> I am trying to install Grass 6.3 from sources on Mac OSX 10.5 and  I
> get the following error:
> "checking External PROJ.4 version... configure: error: *** Could not
> In the config.log file, I see:
> configure:6893: gcc -o conftest.dSYM -g -O2   -I/opt/proj/include conftest.c  1>&5
> Does anybody have any suggestions on what to do?
As William says, set CFLAGS to something without -g when running
configure. Onc configure has finished, you can use e.g.
	make CFLAGS1='-g -O2'
to override the CFLAGS value passed to configure.
A detailed description of the issue can be found in:
http://lists.osgeo.org/pipermail/grass-dev/2008-May/037803.html
This has been fixed in the 6.4/7.0 development versions.
