[GRASS-user] r.fillnulls (GRASS BOOK 3rd edition)
Luís Ferreira lferreira75.2 at gmail.com
Thu Sep 18 21:02:55 EDT 2008
Qui, 2008-09-18 às 15:40 -0700, Hamish escreveu:
> > GRASS 6.4.svn (nc_spm_08):~ > r.fillnulls \
> >   elev_srtm_30m_null out=elev_srtm_30mfilled
> > it gives me the errors
> > /usr/lib/grass-6.4.svn/scripts/r.fillnulls: eval: line 82:
> > unexpected EOF while looking for matching `''
> goes "g.gisenv --help" or just "g.gisenv" work from the command prompt?
> it sounds like GRASS is not fully installed correctly.
> Hamish
I had compiled GRASS 6.4 from https://svn.osgeo.org/grass/grass/branches/develbranch_6 grass6_devel.
                Kernel			: Linux 2.6.26-1-vserver-amd64 (x86_64)
                Compiled		: #1 SMP Thu Aug 28 13:09:10 UTC 2008
                C Library		: GNU C Library version 2.7 (stable)
                Distribution		: Debian GNU/Linux lenny/sid
Code lines in /usr/lib/grass-6.4.svn/scripts/r.fillnulls
                82 eval `g.gisenv`
                83 : ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
                84 LOCATION=$GISDBASE/$LOCATION_NAME/$MAPSET
Using g.gisenv and g.gisenv --help:
                GRASS 6.4.svn (nc_spm_08):~ > g.gisenv
                GISDBASE=/home/lf/GRASSDATA
                LOCATION_NAME=nc_spm_08
                MAPSET=user1
                "GRASS_HTML_BROWSER=/usr/lib/iceweasel/iceweasel"
                GRASS_DB_ENCODING=iso8859-1
                GRASS_GUI=wxpython
                GRASS 6.4.svn (nc_spm_08):~ > g.gisenv --help
                Descrição:
                 Sai e modifica as atuais variáveis de usuário do GRASS.
                Palavras chave:
                 general
                Uso:
                g.gisenv [get=VARIABLE] [set=VARIABLE=value] [store=string]
                   [--verbose] [--quiet]
                Flags:
                 --v   Saída do módulo verbosa
                 --q   Saída do módulo silenciosa
                Parâmetros:
                    get   Variável do GRASS para capturar
                    set   Variável do GRASS para ajustar
                  store   Onde as variáveis do GRASS são guardadas
                          opções: gisrc,mapset
                          padrão: gisrc
 Using gis.m gives:
                82: unexpected EOF while looking for matching `''
                83: syntax error: unexpected end of file
                Locating and isolating NULL areas...
                Reading input raster map <r_fillnulls_12974 at user1>...
                Finding buffer zones...
                Writing output raster map <r_fillnulls_12974.buf>...
                Creating interpolation points...
                Extracting points...
                Building topology for vector map
                <vecttmp_fillnulls_12974>...
                egistering primitives:
                Building areas:
                Número de nós     :   2187
                Número de primitivas:   2187
                Número de pontos    :   2187
                Número de linhas     :   0
                Número de fronteiras:   0
                Número de centróides :   0
                Número de áreas     :   0
                Número de ilhas     :   0
                Topology was built
                0 areas built
                0 isles built
                Anexando ilhas:
                Anexando centróides:
                r.to.vect completo.
                2187 primitives registered
                2187 vertices registered
                Interpolating 2187 points
                Note: The following warnings may be ignored.
                Removing raster <MASK>
                Using segmentation for interpolation...
                Porcentagem completada:
                Carregando dados da tabela de atributos ...
                Lendo linhas do mapa vetorial ...
                Lendo nós do mapa vetorial
                Processing all selected output files
                will require 1818544 bytes of disk space for temp files
                The number of points from vector map is 2187
                The number of points outside of 2D/3D region 0
                The number of points being used is 2187
                há uma faixa com dados insuficientes
                demorando demais para encontrar pontos para
                interpolação--favor alterar a região para a área onde
                estão os pontos. Continuando cálculos... (from
                Portuguese: waiting too long to find points for
                interpolation--please change the region to the area
                where the points are)
                ...(after a while)
                history initiated
                v.surf.rst completo.
                Note: Above warnings may be ignored.
                Patching fill data into NULL areas...
                Creating support files for raster map
                <elev_srtm30m_filled>
                Removing raster <r_fillnulls_12974>
                Removing raster <r_fillnulls_12974.buf>
                Removing raster <r_fillnulls_12974_filled>
                Removing vector <vecttmp_fillnulls_12974>
                Filled raster map is: elev_srtm30m_filled
                Done.
