[GRASS-user] Problems with OpenGL when compiling grass-6.4.0 on Mac OS X 10.5.4
Elvis Dowson elvis.dowson at mac.com
Sun Sep 21 02:23:17 EDT 2008
Hi Michael,
                  Thanks for the reply.
Could you please tell me what I should do to make it work with X11? I am not
planning to use TclTk. I am planning to use vtk-5.2.0 and Qt-4.4.1.
What I need to do is to link grass-6.4.0 or 7.0.0 with X11 and then get it
to work inside vtk-5.2.0. I will then try to use the QVTK plug in to create
a vtkRenderingContext using Qt.
So far, I have managed to get vtk-5.2.0 and qt-4.4.1 compiled and running.
I just have been stuck with getting any version of grass to compile on Mac
OS X 10.5.4 using Xcode-3.1.1.
Could you please help?
Thanks !
Best regards,
Elvis Dowson
Michael Barton wrote:
> Elvis,
> You can compile GRASS 6.4 with TclTk for X11 for Mac with a bit of
> tweaking, but I now recommend that you compile it for TclTk 8.5 aqua.
> You can still have X11 if you need it (e.g., for old GRASS display
> commands).
View this message in context: http://www.nabble.com/Re%3A-Problems-with-OpenGL-when-compiling-grass-6.4.0-on-Mac%09OS-X-10.5.4-tp19588719p19591956.html
Sent from the Grass - Users mailing list archive at Nabble.com.
