[GRASS-user] Re: Problem cannot find grass-6.4.0 plug in in the qgis-0.11.0 plugin settings
Elvis Dowson elvis.dowson at mac.com
Mon Sep 22 05:47:30 EDT 2008
          I tried to rebuild qgis-0.11.0 with the following commands
ccmake CMakeLists.txt
and set the following options
GRASS_PREFIX=/Applications/GRASS/GRASS-6.4.app
GRASS_INCLUDE_DIR=/Applications/GRASS/GRASS-6.4.app/Contents/MacOS/
include
WITH_GRASS=ON
But still qgis doesnt detect the gdal-grass plugin. What should I do?
Best regards,
Elvis
On Sep 22, 2008, at 1:28 PM, Elvis Dowson wrote:
> Hi,
>       I found out that you have to first build gdal without grass
> support, then build grass, and then download the gdal-grass plugin
> and try to build it with grass.
> This is outlined here: http://trac.osgeo.org/gdal/wiki/GRASS
> I then type the following configure command
> ./configure --with-gdal=/usr/local/bin/gdal-config --with-grass=/
> And then it configures correctly!! :-)
> Note that the libraries are located in /Applications/GRASS/
> GRASS-6.4.app/Contents/MacOS/lib but you should just specify
> Applications/GRASS/GRASS-6.4.app/Contents/MacOS  (i.e. do not
> explicitly specify the lib directory).
> Best regards,
> Elvis Dowson
> On Sep 22, 2008, at 12:16 PM, Elvis Dowson wrote:
>> Hi,
>>       I cannot seem to find the grass-6.4.0 plugin in qgis-0.11.0
>> plugin preferences.
>> Could you tell me where it is normally built and if I have to copy
>> the grass-6.4.0 plugin into the qgis-0.11.0 plugin directory?
>> Also, which compilation step builds the plugin? The grass-6.4.0 or
>> the qgis-0.11.0 one?
>> Best regards,
>> Elvis Dowson
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080922/8d573b39/attachment.html
