[GRASS-user] Second try,	run grass scripts as batch process in
	Windows
    Kris Nackaerts
    knackaerts at gmx.net
    Thu Sep 25 03:53:37 EDT 2008
Dear,
This is a quite confusing discussion for a newcomer. People talk about a
'shell' and batch commands which seems to have different meanings.
I do like/prefer the Python approach. But again here, I found out there
seems to be Python scripts for GRASS that have to be run from within
'the GRASS environment'?
Kris
Marco Pasetti wrote:
> Hi Moritz,
> sorry, I'm probably missing the point... but I'll try to help:
>> Note that IIRC, the automatic GUI creation for commands without
>> parameters does not work in Windows (Marco, can you confirm ?). So
>> just calling 'g.region' will probably not work. Try with 'g.region -p'
> if you mean: type a command directly in the shell, that is: not in the
> GRASS Output GUI command line, but from the shell (cmd or msys) that
> started GRASS (calling the grass63 command)
> YES, you're definetely right!
> then, about creating batch processes for GRASS commands, I suggest to
> create scripts with a Unix-like syntax and then launch them within a
> GRASS MSYS session:
> 1. open the GRASS MSYS console:
> http://grass.osgeo.org/grass63/binary/mswindows/native/README.html#Launching%20GRASS
> 2. if you're not sure how to use Unix-like commands, you can basically
> refer to this document:
> http://en.wikipedia.org/wiki/List_of_Unix_utilities
> note: not all the commands listed in the document above are recognized
> by MSYS. To know if a specif_command is known by the system in use, type
> which specif_command
> and enter
> 3. write your batch commands with a simple text editor and then save
> it as "filename.sh" in \GRASS\msys\home\username\ or in \GRASS\scripts\
> 4. launch GRASS from the MSYS console, and then type "filename.sh" in
> the msys command line
> Regards,
> Marco
