[GRASS-user] problem with geographic coordinate
Alfredo Alessandrini alfreale74 at gmail.com
Fri Sep 26 03:57:25 EDT 2008
This GDB was configured as "i486-linux-gnu"...
(no debugging symbols found)
(gdb) r -p
Starting program: /usr/local/grass-6.3.0/bin/g.region -p
---Type <return> to continue, or q <return> to quit---
[Thread debugging using libthread_db enabled]
warning: Lowest section in /usr/lib/libicudata.so.38 is .hash at 000000b4
[New Thread 0xb59eb8f0 (LWP 19677)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0xb59eb8f0 (LWP 19677)]
0xb79a9506 in sincos () from /usr/local/lib/libgdal.so.1
(gdb)
(gdb) bt
#0  0xb79a9506 in sincos () from /usr/local/lib/libgdal.so.1
#1  0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#2  0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#3  0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#4  0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#5  0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#6  0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#7  0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#8  0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#9  0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#10 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#11 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#12 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#13 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#14 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#15 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#16 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#17 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#18 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#19 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#20 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#21 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
#22 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
2008/9/25 Markus Neteler <neteler at osgeo.org>:
> On Thu, Sep 25, 2008 at 10:10 AM, Alfredo Alessandrini
> <alfreale74 at gmail.com> wrote:
>>> g.region -p
>>> and watch out for errors...
> note that your previous mail indicated
> GRASS 6.4.svn (EPSG_4326)
> Below you test something else.
>> GRASS 6.3.0 (EPSG_4322):~ > g.region -p
>> Segmentation fault
> EPSG 4322 is WGS72 (not WGS84). Could a missing NAD file or so
> be a problem?
> Could you run
> gdb g.region
>> r -p
> ... crash ...
>> bt
> (so 'r -p' inside and post the result of 'bt')
> Markus
