[GRASS-user] Second try,	run grass scripts as batch,	process
	in	Windows
    Luigi Ponti
    lponti at infinito.it
    Mon Sep 29 05:32:01 EDT 2008
Glynn Clements wrote:
> Luigi Ponti wrote:
>>> I've started re-writing the scripts in 7.0 in Python. For now, I've
>>> left the Bourne-shell versions in place so that people can compare the
>>> two versions for testing purposes.
>> That's great! Is there already some Python version available?
> So far, I've replaced 16 of the 62 shell scripts in the scripts
> directory. The scripts themselves currently only exist in 7.0,
> although the utility module (lib/python/grass.py) is also in 6.4. In
> most cases, there's no particular reason why the scripts can't be used
> with older versions of GRASS.
Thanks Glynn: I found the scripts. As I go through Lie Hetland's Python
book, it is very useful to have a working GRASS implementation.
Regards,
Luigi
> I also count another 67 shell scripts outside of the scripts
> directory. Some of those are actually Tcl/Tk scripts, some are only
> used during compilation, some are test scripts, etc, but some of them
> will need to be converted in order to be able to run WinGRASS without
> MSys. AFAICT, there are around 25-30 such scripts.
> Compilation will continue to require a Bourne shell, as that's what
> make uses.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080929/143c0760/attachment.html
