[GRASS-user] Problem grass-6.4.0 error setting region: child process exited abnormally
Elvis Dowson elvis.dowson at mac.com
Mon Sep 29 17:15:21 EDT 2008
          I'm getting some errors when trying to use some basic
grass-6.4.0 operations.
I click on Add a Raster Layer and select the aspect file from the
spearfish60 permanent dataset.
After that I click on Display Active Layers and I get an error message
"Error setting region: child process exited abnormally"
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080930/e5a694f3/pastedGraphic-0002.png
After that I get an error message saying" Error can't read
parts(projection)": no such variable
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080930/e5a694f3/pastedGraphic-0003.png
If I click on the details button, I get the following error information:
can't read "parts(projection)": no such variable
     while executing
"regexp -nocase {^([0-9]+)} $parts(projection) trash parts(projection)"
     (procedure "MapCanvas::runprograms" line 46)
     invoked from within
"MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
     (procedure "MapCanvas::drawmap" line 38)
     invoked from within
"MapCanvas::drawmap $mon"
     (procedure "MapCanvas::display_server" line 9)
     invoked from within
     ("after" script)
What could be causing it?  I just built grass-6.4.0 on Mac OS X 10.5.5.
Best regards,
Elvis Dowson
