[GRASS-user] Snapping Points to Nodes along Lines
Ryan R. Rosario uclamathguy at gmail.com
Tue Sep 30 22:28:38 EDT 2008
Hmm. If I do
v.net input=result_from_connect output=projected_points
I do get the point projected onto the line, but I also get points at each
intersection as well as at the end of each street. Is there any way I can
get just the projected points?
This does give me the point projected onto the line, but I
Moritz Lennert-2 wrote:
> On 30/09/08 05:09, Ryan R. Rosario wrote:
>> Thanks. This does seem more in line with what I want to do. What is the
>> difference between operation=connect and operation=nodes?
> connect will connect the points in the points= layer to the lines in the
> input= layer.
> nodes will take the input= layer and create a point at each line end.
> Moritz
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/Snapping-Points-to-Nodes-along-Lines-tp19716703p19753596.html
Sent from the Grass - Users mailing list archive at Nabble.com.
