[GRASS-user] v.dissolve and r.cost problems
Markus Neteler neteler at osgeo.org
Fri Apr 3 04:15:26 EDT 2009
Paolo,
On Fri, Apr 3, 2009 at 10:04 AM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 03/04/09 09:31, Markus Neteler wrote:
>> On Fri, Apr 3, 2009 at 9:20 AM, Moritz Lennert
>>> It implements the same behaviour for all data types: null values are
>>> sorted to the end.
>> Perfect, this works. Please submit.
> Done, in trunk, devel6 and release64.
I have retried your command:
v.dissolve input=regiao layer=1 column=REGIAO output=reg_diss
now it dissolves the map as expected.
Also backported to 6.3 if that helps for you.
Markus
