[GRASS-user] errors in r.drain (develbranch)
Carlos "Guâno" Grohmann carlos.grohmann at gmail.com
Mon Apr 6 13:31:41 EDT 2009
Hello all,
after a full SVN of develbranch, I'm getting errors in r.drain:
Errors in:
/home/guano/pessoal/tmp_install/gis/grass6_devel/raster/r.drain
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Mon Apr  6 14:10:58 BRT 2009
make: *** [default] Error 1
guano[grass6_devel]$ cd raster/r.drain/
guano[r.drain]$ make
gcc -I/home/guano/pessoal/tmp_install/gis/grass6_devel/dist.i686-pc-linux-gnu/include
 -mt
une=nocona -minline-all-stringops -O2 -Wall -D_FILE_OFFSET_BITS=64
-I/usr/include/gdal
   -DPACKAGE=\""grassmods"\"
-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/main.o -c main.c
main.c: In function ‘main’:
main.c:174: warning: format not a string literal and no format arguments
main.c:178: warning: format not a string literal and no format arguments
main.c:183: warning: format not a string literal and no format arguments
main.c:204: warning: format not a string literal and no format arguments
main.c:228: warning: format not a string literal and no format arguments
main.c:242: warning: the address of ‘vect’ will always evaluate as ‘true’
main.c:251: warning: format not a string literal and no format arguments
main.c:270: warning: format not a string literal and no format arguments
main.c:291: warning: format not a string literal and no format arguments
main.c:311: warning: format not a string literal and no format arguments
main.c:323: warning: format not a string literal and no format arguments
main.c:398: warning: format not a string literal and no format arguments
main.c:103: warning: unused variable ‘vect_mapset’
main.c:379: warning: ignoring return value of ‘write’, declared with
attribute warn_unused
_result
main.c:391: warning: ignoring return value of ‘write’, declared with
_result
main.c:497: warning: ignoring return value of ‘read’, declared with
attribute warn_unused_
result
main.c: In function ‘drain’:
main.c:611: warning: ignoring return value of ‘read’, declared with
result
main.c: In function ‘drain_cost’:
main.c:664: warning: unused variable ‘col’
main.c:664: warning: unused variable ‘row’
main.c:681: warning: ignoring return value of ‘read’, declared with
result
main.c:73: warning: ‘dir_mapset’ may be used uninitialized in this function
main.c:84: warning: ‘dir_buf’ may be used uninitialized in this function
main.c:74: warning: ‘tempfile3’ may be used uninitialized in this function
main.c:66: warning: ‘dir_fd’ may be used uninitialized in this function
In function ‘open’,
    inlined from ‘main’ at main.c:387:
/usr/include/bits/fcntl2.h:51: error: call to ‘__open_missing_mode’
declared with attribut
e error: open with O_CREAT in second argument needs 3 arguments
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
guano[r.drain]$
any hints appreciated :)
Carlos
Carlos Henrique Grohmann - Geologist D.Sc.
a.k.a. Guano - Linux User #89721
ResearcherID: A-9030-2008
carlos dot grohmann at gmail dot com
http://www.igc.usp.br/pessoais/guano/
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can’t stop the signal.
