[GRASS-user] working on a mounted external disk
Vincent Bain bain at toraval.fr
Wed Apr 8 04:31:27 EDT 2009
Hello,
has anybody ever had problems accessing a gisdbase located on an
external disk ? In my case, I can open a grass session in a distant
location/mapset :
        grass65 /mnt/path_to_my_disk/my_location/topo
>From within this place, everything works well, OK.
If I start grass from my home directory and try to reproject data from
the distant directory :
        grass65 /home/vincent/my_gisdbase/my_location/my_mapset
        r.proj input=dem50 location=/mnt/path_to_my_disk/my_location
        mapset=topo output=dem50
Then an error occurs :
        ERREUR :Mapset <topo> in input location
        </mnt/path_to_my_disk/my_location/> - not found
whereas the disk is properly mounted there and accessible...
Any idea on why grass seems not to see the mounted directory ?
Thank you
Vincent
