[GRASS-user] NED Shaded Relief, Grass 6.4
Markus Neteler neteler at osgeo.org
Sat Apr 11 02:12:40 EDT 2009
Tripp,
On Sat, Apr 11, 2009 at 8:05 AM, Tripp Lowe <tripplowe at gmail.com> wrote:
> Hello Folks,
> I am trying to create a shaded relief map based on a 30-meter NED file using
> r.shaded.relief.  The results are very 'blocky' (or stair-stepped).  Running
> a 5-cell average neighborhood across the DEM did not help. Can somebody tell
> me the correct procedures I should follow to create the relief map that is
> smooth?
> I've put a screenshot of my initial shaded relief map up here to show you
> what I'm talking about...
> http://www.rlogis.com/GMaps/test/grass64_shadrel.jpg
did you run
g.region rast=your_ned_map -p
before
r.shaded.relief
? I suspect that your current region is of lower resolution right now.
Markus
