[GRASS-user] Re: v.lidar.growing dbmi: Protocol error
Jack Lonsdale lonsdale at unbc.ca
Wed Apr 22 18:08:02 EDT 2009
On Wed, 2009-04-22 at 23:26 +0200, Markus Neteler wrote:
> >> firstly, just to check, the 'first' parameter is the raw dataset?
> To my knowledge, no.
> AFAIK it is the *last* return which is input to v.lidar.growing.
Just to clarify: by 'first' I mean the first pulse vector map. On the
help page the usage example only states you need an input and an ouput
vector, but upon trying this the software insists on the input of a
'first=' parameter
> >> If not how do I create the first return dataset?
> You can use v.extract to separate a mixed map into the different
> returns (eg based on an attribute identifying the pulse).
I don't know how I could manage this, the only inputs I have are the
x,y,z and intensity?
> >> Secondly, if I run the following:
> >> v.lidar.growing input=alrf_subs_edge at lonsdale output=alrf_subs_grow
> >> first=alrf_subs_raw tj=0.2 td=0.6
> >> All I get is a dbmi:Protocol error, It was impossible to open this
> >> table!
> Please send the precise error message.
> But it may be that the (if so) previous error of using the wrong input
> isn't ideally trapped.
The precise error message is as above 'dbmi:Protocol error, It was impossible to open this table'
> >> I have seen someone else had this problem on the list in the past but no
> >> definitive solution seemed to occur.
> In our book we have successfully used the modules to produce
> http://www.grassbook.org/gallery/chapters/s070302f010_cutplanes.jpg
> so it worked for us.
> Markus
Thanks for the help so far though
