[GRASS-user] r.thin
d c danotchki at gmail.com
Mon Apr 27 11:23:42 EDT 2009
Thanks, Juan.
This worked. Not exactly the result I expected (resulting vector layer far
too simplified) but it worked ;-)
All the best.
Danny
On Sun, Apr 26, 2009 at 9:04 PM, Juan Carlos Torres Cantero <jctorres at ugr.es
> wrote:
> Danny
> The algorithm run an iterative process. At each step its remove external
> cells
> from the feature, and test if the result is correct. The parameter you must
> enter to "iterations" is half the number of cell of your  wider line on the
> map.
> Juan Carlos Torres
> On Sunday 26 April 2009 17:47:55 d c wrote:
> > Hi,
> > I'm trying to use r.thin before running r.to.vect.
> > The man page says to use the thickness as parameter for *iterations*.
> > I'm not sure I understand what it means by "thickness".
> > Any ideas?
> > Many thanks,
> > Danny
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090427/588002d7/attachment.html
