[GRASS-user] Importing, Defining, and Georeferencing
Juan Carlos Torres Cantero jctorres at ugr.es
Mon Apr 27 12:02:06 EDT 2009
Joe
You can import it both ways. Using a predefined location or asking
r.in.gdal to create a new one.
Anyway, you'll get three RASTER maps corresponding to the three colors
chanels (tiff files are raster). If you want a color copy of the input
map youl'll
need to use r.composite to mix them. And if you need a vector map you'll
need to extract features from the raster map thin them and convert to
vector
using r.to.vect.
Juan Carlos Torres
Joe Bayles escribió:
> Hello, I'm trying to figure out how to use GRASS (brand new user) and
> I am having a hard time switching over. I have a TIFF file I want to
> import and from that create a vector map using georeferencing. Every
> time I think I've imported it correctly, nothing shows up. I've done
> this both before and after creating a new map set, though I don't know
> how effective that was. I have been using r.in.gdal, but I don't know
> if this is what I want. I know this is a bit of a general question,
> but I'm a bit lost. Thanks.
> Joe
> grass-user mailing list
> grass-user en lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
