[GRASS-user] PostgreSQL append
    Pavel Iacovlev
    iacovlev.pavel at gmail.com
    Sun Aug  2 17:35:38 EDT 2009
I am very new to grass so I am not sure if it's a bug or not, maybe I
defined my "location" incorrectly, how do I check ?
select * from geometry_columns where f_table_name = 'flood'
f_table_catalog f_table_schema  f_table_name    f_geometry_column
 coord_dimension srid    type
       public  flood   wkb_geometry    2 900917 POLYGON
On Sun, Aug 2, 2009 at 11:25 PM, Markus Neteler<neteler at osgeo.org> wrote:
> On Sun, Aug 2, 2009 at 9:43 PM, Pavel Iacovlev<iacovlev.pavel at gmail.com> wrote:
>> Good day all,
>> 1.
>> I have a vector grass file and I want to append it's data to a
>> PostgreSQL table, atm I use the following command:
>> v.out.ogr input=flood_vect type=area 'dsn=PG:host=localhost
>> dbname=gisdb user=gis password=*' olayer=flood layer=1
>> format=PostgreSQL lco='OVERWRITE=YES'
>> This command overwrites the postgis table, I want to append the data.
>> If I remove the lco='OVERWRITE=YES' I just get and error that the
>> table already exists.
> The OGR tools support is:
> ogr2ogr -update -append ..
> but I am afraid that v.out.ogr does currently not.
>> 2. When I export vector data to a PostgreSQL table it sets the wrong SRID
>>> g.region -p
>> projection: 3 (Latitude-Longitude)
>> zone:       0
>> datum:      wgs84
>> ellipsoid:  wgs84
>> north:      47:04:48.37738N
>> south:      46:55:11.265564N
>> west:       28:44:44.481812E
>> east:       28:58:20.944519E
>> nsres:      0:00:02.885559
>> ewres:      0:00:02.885027
>> rows:       200
>> cols:       283
>> cells:      56600
>> the SRID of the geometry is 900917,
> Do you mean 900913 (the unofficial outdated Google Mercator EPSG code)
>> I expect it to be 4326 (wgs84) what am I doing wrong ?
> It should be like that. I currently have no PostGIS installed for
> a test. Maybe someone else in this list...
> Markus
http://iap.md, The future is open
