[GRASS-user] Network analysis
Giovanni Pasini jynxtor at gmail.com
Mon Aug 17 05:26:12 EDT 2009
David Dabin ha scritto:
> Dear Grass Users/Developpers,
> I am studying the distribution of car accidents on a road network. In
> order to define hotspots and hotzones (succession of hotspots on a road)
> based on a  local density of accidents computed on the network, I use
> the v.net.alloc function (to allocate a subnet to each accident event).
> For the moment, the density is thus expressed per "Thiessen" segment. To
> illustrate, Typical output is similar to
> ----x---|---x-|-x--|--x----
> where
>    x: is the location of one or many accidents,
>    -: is a piece of the network,
>    |: is the limit of the Thiessen segments
> My density of accident is simply the number of accident divided by the
> length of the Thiessen segment. Howerver, as you can notice from the
> example, the Thiessen segments (|---x-|) are not symmetric relatively to
> the accident location. I thus would like to compute the length on the
> right and on the left of each segment. I have tried to cut the output of
> v.net.alloc with v.edit and coordinates of accident but it do not works.
> Do you have an idea on how to proceed and which function should I use or
> implement?
> Thanks in advance,
> David
> grass-user mailing list
> grass-user a lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
Not responding to your question...
see also v.kernel [1] > vector density map on vector network with a 1D
kernel
[1] http://grass.itc.it/grass64/manuals/html64_user/v.kernel.html
giovanni
