[GRASS-user] magic?
achim ak7 at jupiter.uni-freiburg.de
Thu Aug 20 08:03:42 EDT 2009
Hello,
I used v.to.rast
    v.to.rast --overwrite input=inmap output=outmap use=cat
to convert 29 areas to raster.
It says
    Converted areas: 29 of 29
but one area is missing!!!
Its the one with cat number 16. Doing the same just for the selected 16,
conversion results in am empty raster map.
the same with use=attr or usr=val. Another vector map also does not
convert some areas. The missing areas are not special
What happens? Magic?
I tried it with grass64 and newly compiled grass65. (OpenSuse 11.1 64bit)
Achim
PS:
Layer: 1
Typ       Anzahl        Min        Max
Punkt          0          0          0
Linie           0          0          0
Grenze       0          0          0
Zentroid      29          1         29
Fläche           0          0          0
Alle           29          1         29
