[GRASS-user] wxpython Mac OS X compilation issues
stephen sefick ssefick at gmail.com
Fri Aug 21 18:11:52 EDT 2009
I do not have
/Library/Python/2.5/site-packages/wx.pth
how do I get it?
On Fri, Aug 21, 2009 at 8:58 AM, William
Kyngesburye<woklist at kyngchaos.com> wrote:
> wxpython should work fine with the system python.  I don't remember how the
> installer works to do this, I think it's automatic.
> Do you have:
> After starting GRASS, run Python within the GRASS shell.  What do you get
> from:
> import sys
> sys.path
> On Aug 21, 2009, at 8:39 AM, stephen sefick wrote:
>> I first used the system python and then I installed the latest
>> wxPython.  Should, I go through and only use the system python, make
>> use of the newest python, or...?  Thanks for the help.
>> Stephen Sefick
>> On Fri, Aug 21, 2009 at 8:33 AM, William
>>> On Aug 20, 2009, at 11:36 PM, stephen sefick wrote:
>>>> from with in GRASS
>>>> g.gui wxpython
>>>> ERROR: wxGUI requires wxPython >= 2.8.1.1.
>>>> dlopen(/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python/wx-2.8-mac-unicode/wx/_core_.so,
>>>> 2): Symbol not found: __ZN15wxPoint2DDouble14SetVectorAngleEe
>>>>  Referenced from:
>>>>  Expected in:
>>>> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libwx_macud-2.8.0.dylib
>>>> . Detailed information in README file.
>>>> Any help tracking this down would be gratefully appreciated.
>>> For some reason, GRASS is not using your wxpython.  Maybe it's not in
>>> your
>>> sys.path.
>>> Did you install the python.org Python or are you using the system python?
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> "This is a question about the past, is it? ... How can I tell that the
>>> past
>>> isn't a fiction designed to account for the discrepancy between my
>>> immediate
>>> physical sensations and my state of mind?"
>>> - The Ruler of the Universe
>> Stephen Sefick
>> Let's not spend our time and resources thinking about things that are
>> so little or so large that all they really do for us is puff us up and
>> make us feel like gods.  We are mammals, and have not exhausted the
>> annoying little problems of being mammals.
>>        -K. Mullis
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> "History is an illusion caused by the passage of time, and time is an
> illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
Stephen Sefick
								-K. Mullis
