[GRASS-user] reproject from lat/long to utm
Janet Choate jsc.eco at gmail.com
Wed Dec 2 01:28:41 EST 2009
I tried using the full path (i.e. the PERMANENT mapset lives within the
/work/projects/Willamette location), but get the 'not found' error.
is there any other command i need to run prior to r.proj, or any additional
options to include, or how to list the path other than the way i am?
the original data i imported was a dem from usgs national elevation dataset
(ned) seamless data distribution system (sdds).  i had to export it from ned
as a geotiff to bring it into grass.  i tried exporting the data from ned as
an arcgrid and importing into grass with r.in.gdal, but was unable to bring
it into grass.
so if anyone can tell me the steps to bringing ned seamless data into grass,
then reprojecting to utm, i would be grateful.  or at this point, just how
to use r.proj to reproject to utm.
thanx, janet
On Tue, Dec 1, 2009 at 10:14 PM, maning sambale
<emmanuel.sambale at gmail.com>wrote:
> Try to include the full path of your location ([/work/projects/Willamette])
> On Wed, Dec 2, 2009 at 1:47 PM, Janet Choate <jsc.eco at gmail.com> wrote:
> > HI,
> > thanx for any help.  seems this should be a pretty straight forward thing
> to
> > do, but am not having any success.
> > i am trying to reproject a raster from lat/long to utm.
> > i created a new location with a utm projection, then tried to use r.proj
> to
> > reproject a raster from another location.
> > r.proj input=dem location=/work/projects/Willamette mapset=PERMANENT
> > however, i get the following error:
> > Mapset [PERMANENT] in input location [/work/projects/Willamette] - not
> found
> > thanx for any assistance,
> > Janet
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091201/9c36cd30/attachment.html
