[GRASS-user] Re: Georectify problem
Adam Dershowitz, Ph.D., P.E. adershowitz at exponent.com
Wed Dec 2 11:34:47 EST 2009
I did try it, but I can't currently get it to run.  My guess is that it is an issue of the current built of GRASS that I am using (6.4 RC5-3 on a 64 bit machine):
g.gui wxpython
  File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/wxgui.py", line 55, in <module>
    import gui_modules.globalvar as globalvar
  File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gui_modules/globalvar.py", line 59, in <module>
    import wx
  File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/__init__.py", line 45, in <module>
    from wx._core import *
  File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py", line 4, in <module>
    import _core_
ImportError: dlopen(/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core_.so, 2): no suitable image found.  Did find:
	/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core_.so: mach-o, but wrong architecture
--Adam
On Dec 2, 2009, at 6:47 AM, Michael Barton wrote:
> Important to note that this will not work with Windows, since Windows doesn't run x11 unless you the Cygwin unix emulator.
> Have you tried georectification with the new wxPython GUI?
> Michael
> On Dec 1, 2009, at 11:20 PM, grass-user-request at lists.osgeo.org wrote:
>> Date: Wed, 02 Dec 2009 15:01:23 +1100
>> From: Richard Chirgwin <rchirgwin at ozemail.com.au>
>> Subject: [GRASS-user] Re: Georectify problem
>> To: grass-user at lists.osgeo.org
>> Message-ID: <4B15E693.1010909 at ozemail.com.au>
>> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>> Adam,
>> If all else fails, work with a command line process ... I've never had
>> happy experiences with the purely GUI rectification.
>> i.group (groupname) (mapname)
>> i.target (groupname) Target_Location Target_Mapset
>> d.mon X0
>> i.points (groupname) - this launches the GCP capture GUI (old style,
>> X-windows but it works!)
>> i.rectify (groupname) extension="something" order=(polynomial order)
>> RC
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
