[GRASS-user] Re: CYGWIN
Luigi Ponti lponti at infinito.it
Thu Dec 3 13:51:14 EST 2009
Dear Glynn and Markus,
I found no follow-up to this message of last November 17 so I am
replying to this one.
On windows 7 and using a fresh Cygwin/GRASS install as per instructions at
http://grass.osgeo.org/grass64/binary/mswindows/cygwin/
I start Cygwin shell -> startxwin.sh -> grass64 -tcltk
The startup GUI pops up, I select a mapset, and press "enter GRASS" as
usual.
I get a very similar error to that reported by Markus below, i.e.:
    5 [main] g.gisenv 4772 _cygtls::handle_exceptions: Exception:
     STATUS_STACK_OVERFLOW
       358850 [main] g.gisenv 4772 open_stackdumpfile: Dumping stack trace
     to g.gisenv.exe.stackdump
(every time you get same message with different numbers)
Also, by calling GRASS in the following way:
    grass64 -tcltk 2> logGRASS.txt
The content of the log is
    /usr/local/grass-6.4.0RC5/etc/Init.sh: line 837: tput: command not found
Hope this help better diagnosis. My apologies if I missed follow-up to
this thread.
Kind regards,
Luigi
> Date: Tue, 17 Nov 2009 12:54:46 +0000
> From: Glynn Clements <glynn at gclements.plus.com>
> Subject: Re: [GRASS-user] CYGWIN
> To: Markus Neteler <neteler at osgeo.org>
> Cc: GRASS user list <grass-user at lists.osgeo.org>
> Message-ID: <19202.40214.211883.542609 at cerise.gclements.plus.com>
> Content-Type: text/plain; charset=us-ascii
> Markus Neteler wrote:
>> > Starting grass64/cygwin with -tcltk leads to
>> > 13 [main] g.gisenv 2100 _cygtls::handle_exceptions: Exception:
>> >   78803 [main] g.gisenv 2100 open_stackdumpfile: Dumping stack trace
>> > Subsequently the GUI isn't started (the tcltk startup screen comes up well).
>> > Running on command line:
>> > g.gisenv
>> > returns the settings as it should.
>> > g.region -p
>> > returns to command line without printing anything.
>> > Perhaps there is a version conflict with the proj libraries?
> All of the above work for me.
> -- Glynn Clements <glynn at gclements.plus.com>
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091203/460c0ed7/attachment.html
