[GRASS-user] Re: CYGWIN
Luigi Ponti lponti at infinito.it
Fri Dec 4 02:30:25 EST 2009
On 04/12/2009 07:58, Glynn Clements wrote:
> Luigi Ponti wrote:
>> On windows 7 and using a fresh Cygwin/GRASS install as per instructions at
>> http://grass.osgeo.org/grass64/binary/mswindows/cygwin/
>> I start Cygwin shell -> startxwin.sh -> grass64 -tcltk
>> The startup GUI pops up, I select a mapset, and press "enter GRASS" as
>> usual.
>> I get a very similar error to that reported by Markus below, i.e.:
>>     5 [main] g.gisenv 4772 _cygtls::handle_exceptions: Exception:
>>      STATUS_STACK_OVERFLOW
>>        358850 [main] g.gisenv 4772 open_stackdumpfile: Dumping stack trace
>>      to g.gisenv.exe.stackdump
> Can you post the contents of the g.gisenv.exe.stackdump file?
Here it is:
   9888 [main] g.gisenv 3672 _cygtls::handle_exceptions: Exception:
STATUS_ACCESS_VIOLATION
  11805 [main] g.gisenv 3672 _cygtls::handle_exceptions: Error while
dumping state (probably corrupted stack)
Thanks for your reply,
Luigi
>> Also, by calling GRASS in the following way:
>>     grass64 -tcltk 2> logGRASS.txt
>> The content of the log is
>>     /usr/local/grass-6.4.0RC5/etc/Init.sh: line 837: tput: command not found
> This is harmless; the only consequence is that the terminal window
> won't be cleared. The "tput" program is in the "ncurses" package,
> which isn't otherwise required (the libraries required by curses-based
> programs are in a separate "libncurses9" package).
>> Hope this help better diagnosis. My apologies if I missed follow-up to
>> this thread.
> I don't think that there has been any follow-up.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091204/f4a9ba25/attachment.html
