[GRASS-user] Re: CYGWIN
Luigi Ponti lponti at infinito.it
Sat Dec 5 02:43:30 EST 2009
On 04/12/2009 20:36, Markus Neteler wrote:
> On Fri, Dec 4, 2009 at 12:04 PM, Glynn Clements
> <glynn at gclements.plus.com> wrote:
>> Luigi Ponti wrote:
>>>> Can you post the contents of the g.gisenv.exe.stackdump file?
>>> Here it is:
>>>    9888 [main] g.gisenv 3672 _cygtls::handle_exceptions: Exception:
>>> STATUS_ACCESS_VIOLATION
>>>   11805 [main] g.gisenv 3672 _cygtls::handle_exceptions: Error while
>>> dumping state (probably corrupted stack)
>> Unfortunately that doesn't help.
>> I don't think that we will be able to make any progress on this until
>> someone who can reproduce it can get a backtrace out of gdb.
> ... which isn't that hard. If you need help, Luigi, let me know.
Is this the place to start from?
http://grass.osgeo.org/wiki/Compile_and_Install
Is it a matter of trying compiling on Cygwin? I assume that gdb is the
debugger of gcc.
I remember threads on Cygwin compilation but I was not able to find them
on the mailing list archive. If somebody has a pointer to relevant
threads/resources, that would be appreciated.
Regards,
Luigi
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091205/1ab54e9c/attachment.html
