[GRASS-user] bug?: v.to.db wrong area
Achim Kisseler ak7 at jupiter.uni-freiburg.de
Mon Dec 7 12:32:14 EST 2009
Hi Markus,
its the same with hectares; kilometers writes out the result in
square-kilometers.
Achim
Markus Metz schrieb:
> Achim Kisseler wrote:
>> Hi,
>> I am using
>> v.to.db map=af_grid option=area columns=area type=centroid
>> units=kilometers
> try units=hectares, kilometers are not an areal unit, don't know why
> v.to.db executes at all
> you can cross-check the results by querying the map
> hope that helps,
> Markus M
>> (in GRASS65 opensuse 11.1 64)
>> to calculate the area size. Some of the areas are very wrong. Its a grid
>> in lat-lon, where areas should be nearly equal in size.
>> Is this a known bug? I don't guess so.
>> Do I something wrong?
>> Thanks,
>> Achim
>> PS:
>> already did v.clean, r.mask -r (<- should not be have an effect)
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
